New House - What is this "Heat Bank"?
10 Feb 2025
Hi all,
I've just moved into a new house and I'm looking for some clarification on how my hot water system works.
I'll explain how I THINK it works, and hopefully someone here can maybe clarify if I'm a million miles out, partially wrong, or somehow correct. It all kind of stems down to a mixture of how does this system work, and is this set up really inefficiently?
There is what I assume to be your standard Worcester Bosch boiler upstairs in the cupboard. It's a Greenstar 24Ri ErP... whatever that means.
This directly does the central heating for the house, and indirectly does the hot water (more on that later).
It's controlled by a Honeywell ST9400C, which is connected to a thermostat in the hallway downstairs. I've programmed this to trigger the central heating at set times of day and turn off and other times, but it's also reliant on the temperature to be below that on the thermostat. So if I turn the thermostat down and forget about it, the next morning the house is going to be cold because I forgot to turn the damn thing up before I went to bed.
I've also programmed this to do the hot water at different times of day, but to be quite frank I have no idea if it's even doing anything with that because of the way the hot water system appears to work.
So, about that hot water system. In the spare bedroom cupboard (whatever genius chose that location needs a good slap), there is what I originally assumed to be the hot water storage tank of the "standard" type. As in the water in the tank is the water that I'm using to fill the sink, shower etc. After moving in however, I found out it's actually a Pandora Heat Bank, a thermal store , details of which are located here https://www.heatweb.co.uk/w/images/e/e0/DS-20_Pandora_Indirect.pdf
Now from what I've read it says that when I use the central heating, it also heats the water up in this thermal store. Okay fine, killing two birds with one stone, that makes sense. The store then has a heat exchanger so when I want to use the shower the mains water comes through, gets heated up by the stored hot water on the other side of the heat exchanger, and I get a really nice powerful mains water pressure hot water shower, that if I so decided I could actually drink. All this works and I must say the water pressure is great and the wife likes the fact the bath fills up quick.
The confusion/problem comes from the fact this thermal store has a 3kW immersion heater on it as well. After moving in I kept hearing this damn tank doing something and it's pretty loud if you are in the room when it does. I originally thought it might be a pump just recirculating the water inside the tank, but based on the fact my electricity usage suddenly goes up by 3kW, I think it's safe to say it's the immersion heater kicking in. I kept an ear out for it today whilst in my office in the next room and it kicked in roughly every 30 minutes for 3-5 minutes. Middle of the day, central heating not on. So what the hell is this actually doing? Is it trying to keep the water in the tank above a minimum temperature? By my calculations, this thing kicking in roughly 48 times a day, for 3-5 minutes at a time, is going to cost me £2.60 a day, or £950 a year. It even seems to come on when the central heating is already on!
So my questions...
-Why does the 3kW immersion heater need to come on if the tank is being heated by the boiler?!
-Come summer does that mean all my hot water is going to be supplied by a 3kW immersion heater because the boiler never comes on for the central heating?
-Why am I setting the Honeywell control system up for "hot water" times if the tank just stays the same temperature all day and night? Is that just a redundant part of the controller because it's based on a different type of system? Because as far as I can tell, the boiler never kicks in just to heat the water in the tank, it only comes on to do the central heating.
-There is a temperature gauge on the tank which seems to be a steady 75'C, but there is also a dial thermostat on the tank that's at 65'C. Is that tank temp vs outlet temp? Is that temperature too high and should be turned down?
Any information or recommendations on how this system works, how to set it up for efficiency etc are much appreciated.
If you read the link you gave to the information of the cylinder, it tells you that the immersion is a backup - so it must be turned on if kicking in, my advice is turn it off.
Secondly, from the diagram the heating water is used to heat the cylinder, not just for when the central heating is on, how a lot of vented cylinders work, S plan or Y plan system, if the same as the diagram then it’s an S plan
Thirdly, why are you turning down the heating temperature?
Just FYI, the boiler is a regular boiler, ERP = Energy Related Product
I assumed as a "backup" it just meant it would come on when it needs to. I didn't realise it was a "if your boiler blows up and you still want hot water" kind of backup. I haven't touched anything to do with the system short of changing the timings on the programmer since moving in. I've found the switch for it and turned it off, so we'll see if I still get hot water.
Maybe the reason the boiler never seems to kick in to heat the water tank when the CH is off, is because the immersion heater was on all the time. Will now see what happens with the immersion heater off.
I'm not saying I want to turn it down. I'm just not sure how it's meant to be set up and was asking if it needs to be adjusted. Especially with the water tank being 10'C higher than what the thermostat on the tank says.
Thanks for the response though. If it turns out that the immersion heater isn't meant to even be on, that's a real facepalm moment. Even if I wasn't the one who turned it on.
Ok, so you sound like you’re halfway there. The cylinder thermostat needs to be in the region of 60 degrees. The thermostat for heating is usually an average between 18 and 23, all depends on your comfort levels. Yes, you should still get hot watery unless there’s an issue undisclosed.
