Hot Water Too Hot
23 Jun 2013
Leicester
Hi All
Keen DIY'er slight problem with my central heating. Y plan central heating system. Hot water is very very hot. CHANGED:- Tank Thermostat, Actuator Head, 3 Port Valve, Checked Programmer temporarily fitted a neighbours. What else could cause hot water to heat well over 60°C as set by tank thermostat..? Tank does have immersion heater but its not switched on..
Please Help !!
Gav
Thermostat 1/3rd up from bottom of tank.
Hot water rises.
Boiler runs circa 75 degrees.
Go figure.
Thanks Dan
Tank Stat never been moved in same place for 12 years. Hot water just started to get hot. As I said changed likely suspects but still hot..
Or are you saying lower tank stat to about 50°C ?
Lowering the stat. Would be a good test.
Has your immersion been accidentally turned on?
Immersion is definately off? What type of actuator have you got, some can play silly beggars, esp the Sunvic models.
Immersion definitely OFF (no light on switch). The actuator was swapped like for like replacement Danfoss HSA3 and a Danfoss HSV3 Valve. Ive read danfoss are not the best either..
Never had any major problems with danfoss. No worse than any other IMO
I think u need to do some testing
Turn hw to constant/on
Turn cylinder stat up.- hsa3 valve should motor open and boiler should fire.
Turn cylinder stat Down- valve should close and boiler turn off
Does this happen?
Immersion definitely OFF (no light on switch)..
So, if you asked a gaggle/gossip (or whatever the collective noun for 'plumbers' is...) of plumbers how often a boiler/immersion heater switch has been installed with incorrect polarity, upside down, neon indicator blown etc you might be unpleasantly surprised (as has many of us who 'assume' - the first time only-that off is is indeed off).
Take a voltage reading (carefully) at the terminals on the Imm Htr to see if it truly 'OFF', or not.
And turn off the boiler, to see if temp still rises.
DH
I can isolate immersion from main consumer unit so I know its definitely off. The only possibility is the tank stat has been turned either by one of my children or when something has been removed that we store in the airing cupboard. ive just set it to 60°c as I've read this is the required setting to kill bacteria. It could have been set lower. Unfortunately I don't have a thermometer to test water temp.
Gav
Have you tested it as I've suggested?
OK heating turned on constant, turn tank thermostat turned up until a click, Pump starts going , Boiler fires up, Actuator does NOT move..
Tank thermostat turned down until a click boiler and pump both stop shortly afterwards, actuator does NOT move again..
Gav
UPDATE
Ran a few checks..
Heating on constant : Turn Room Thermostat UP, Boiler fires up and pump starts and Actuator moves, Turn Room Stat down Actuator turns back. pump goes off as does boiler
Still with Heating turned on I turned Hot water on constant . Turned Tank stat up Actuator moves, Turned tank stat down actuator turns back.
hope you understand
Gav
Your cyl stat is wired incorrectly by the sounds of it check the wiring
Matt
Really?
OP - 60c is HOT. Like steaming hot
How do you know its over 60c if you havent got a thermostat to test it? I wouldnt hold my hand under 60c water.
Any temp over 50c is safe for HW, 55c is an average.
