Hi, i will do the bucket test this weekend. I have been reading posts and watching vids for 3 weeks now. Could someone out there possibly please point me in the right direction? Or at least give me an order of what to try first? Thanks in advance.
Scenario .
I took two old radiators out and capped the ends whilst I built a room in a room stud walls (soundproofing). I needed the radiator on the opposite wall so I ran the 15mm copper in the void up into the ceiling, around the ceiling and back down to the opposite wall (yorkshire fittings). Hung the new rad and fitted new trv and locksheild. It does not get hot. It gets full and I can bleed it with no gurgling of air, but no heat. I can watch the boiler water level drop as I bleed it. I'll list what I have done/ thoughts.
1) I do not know if I have the flow and return pipes correctly orientated. I did not check 1st = idiot! Would i still get some warmth? The old radiators used the get hot and I just extended pipework. Should I try switching them? Bodge it with push fits to test?
2) can a new trv valve be stuck? I have gently tapped it. Screwufix says they are bidirectional, so it shouldn't be the flow/ return issue?
3) if it is full of water cannot be an airlock?
4) I turned off all other rads and put the heating on. No joy. So not a balancing issue?
5) I bought another rad tail and was gonna do a youtube video where I remove bleed valve and drain with hose pipe from that outlet with valves closed. Is there a simpler fix? To remove airlock.
I know just enough to be dangerous!!! Any recommendations on what to do/ do first please. This room is costing an arm and...
Thanks for reading.
Scenario .
Thanks for reading.
