Hi everyone,
I have to add a radiator to a system. It is 8mm pipework.
The manifold is 28mm with the 12 pipes (6 rads) coming off it.
There are no blanks to use.
The flows and returns for all the radiators go into the manifold together all next to each other. Manifold is about 150mm in length before going to 22mm.
Can I tee into the 22mm pipe after the manifold then go into another tee and put the new flow into the end of the tee and the return into the branch obviously all reduced down to 8mm?
If not what should I do?
What is this type if system called?
Regards
Regards
