Hi
I have 22mm flow and return pipes running parallel to each other centrally from front to back of my house in the void under the floorboards upstairs (each 22mm pipe is approx. 8 metres long). At each end of each of these pipes is a manifold where the pipes to/from the radiators are connected (mostly 8mm microbore to the rads). Some of these 8mm runs to the rads are 6-7 meters long. The airing cupboard/pump is located directly on top of the 22mm pipes and about 2/3's the way along the run.
I need to replace and move 3 rads and their new locations will end up being much closer to the 22mm pipes than currently. The new rads will be 1800x452mm column rads (3262 BTUs each).
My question is, can I tee off anywhere along the 22mm flow and return pipes and run the new supply pipes to the new rads (runs of probably only 3 metres max in 10mm) and then just cap off some of the manifold outlets that are now not needed? (the other rads that are not being moved will still be connected by 8mm to the manifolds) Or do the pipes to the new rads still have to come off the manifolds at the ends of the 22mm pipes (even though this means much longer runs to the rads?)
