I was going to install a 15mm central heating system but am now considering 10mm microbore for ease of installation.
There will be 4 downstairs rads and 4 upstairs rads.
Have I got this right?
the 22mm flow pipe should end in a manifold, out of which would be 10mm pipes to the rads (4 10mm pipes for the groud floor). From the return valve of the rads the 10mm pipe would go to the return manifold connected to the 22mm return pipe. Is this right? OR do i form a loop in the 22mm flow and return as with 15mm and take of stems with manifolds on?
Also, is it best to split the 22mm flow pipe before the manifolds, one for upstars and one for downstairs.
Also, is it possible to use 10mm in the same way 15mm, without using manifolds?
Doesn't seem to be much info online. Help would be appreciated.
Chris
Chris
