New room stat doesn't need a netural
16 Jul 2009
Hull
If replacing a hard wired room stat. That only requires a com and no Wires. What is safe to do with the neutral that is no longer needed?
simply make sure it cannot touch anything, typically by placing it in a single piece of connector block or other secure method. Ideally not plastic tape which over the years will dry and fall off.
Thanks so if I put in a single connector block then tape as well?
