My System: A Cold Water Tank in the loft, with a smaller tank next to it for the central heating. The tank has the usual ball float controlling water coming from the mains, and two pipes at the bottom of the tank – one feeding cold water, and the other the hot water. We have a hot water cylinder in the airing cupboard, and a boiler downstairs.
The Problem: We had a shower room installed a few months ago downstairs near our boiler. It works fine, but whenever it is used hot water backs up into the hot water feed in the bottom of the Cold Water Tank. This causes the tank to overflow and water to pour out of the overflow pipe. Even though the shower is only on for 15-20 minutes this continues for several hours, gradually diminishing in pressure and then stopping.
This problem does not happen with the upstairs shower so I can only guess it is the new shower that is causing the problem. I’m reluctant to call the builder who installed the new shower as it appears he has caused the problem in the first place (at least I’m assuming he has).
Any ideas or help would be greatfully appreciated.
