- Joined
- 8 May 2017
- Messages
- 10,686
- Reaction score
- 2,883
- Country
OK got that ,but does this work EVERY time ? I.e use bath hot to activate pump ?. Is the supply pipe to pump 22 mm diameter ,and to tap 22 mm and 15 mm to shower ? Is there an isolator on the branch to the shower ,AFTER the pump and bath tap ? If so ,is it a full bore isolator ,lever operated ,or of the type that you use a screwdriver on to close / open ?
