New shower pump installation
10 Feb 2007
Cumbria
Gravity fed copper cylinder
Mains pressure cold water
Shower on same level as the cylinder
Question. Is there a pump that could reduce the cold water pressure and booster the hot water all in one neat package to slot under the bath? (or have a I stumbled upon a new invention?).
So the gravity hot would be next to nothing in pressure whilst the cold may be over 3 bar.
The thermostatic shower valve itself acts as a restrictor for the 3bar of cold. You just want a pump which tees into your hot water feed, i assume.
Salamander are usually the brand i look for.
Assuming you have an electric shower at the minute...? (Just a cold feed...?)
Loads of them about - pop onto screwfix... first one i came across was item 2713d (weirdly, not a salamander...!) but lots available online too.
Mike2007 Have you considered a shower mixer valve that will cope with cold mains & hot tank supply.There known as venturi shower mixers and work fairly Ok but need to be installed and set up correctly.
if you really want a pump,its best to pump the cold and hot from the same source (tank).
They work Ok,shower head flow is iirc 8lpm.Not as powerfull as a pumped system but silence comes at a cost.
Purchased 3 last year,now special order only and expect to pay around £490 :!:
