Hi all,
Just looking for some pointers on my driveway. I'm adding two rows of slabs to get my car in on and then was planning for gravel all around.
I'm planning to dig out 200mm all over, then fill with the following -
- 120mm type 1 sub base.
- 30mm sharp sand (under the gravel) or 30mm dry sharp sand and cement mix (under the slabs).
- 50mm gravel or 50mm concrete slabs on the top.
I'm just looking for a sanity check as i've never done this before! Does that seem correct?
Should I still have sand between the sub base and gravel, or just a thicker layer of gravel?
What ratio sand and cement should i use under the slabs? Should it be a dry mix?
I'll get a compactor for the sub base, should i use it on the sharp sand too?
Any other advice would be appreciated!
Thanks,
Iain
Thanks,
Iain
