New Tiling project
14 Sep 2010
Lancashire
Hi all,
I am about to tile my entire bathroom and it is not a cube or cuboid. It has varying floor to height ceiling on 3 walls.
My first problem is how to tile this wall:
My tiles are 300mm x 400mm wide. I am using them length ways
The wall in question is 1680mm wide.
4 tiles = 1600
4mm grout lines = 16mm
== 1616
Leaving 64mm.
Now I dont want to have a thin strip so how do I avoid this???
Start with a half tile then three full tiles then a cut to suit the space you have left. Obviously that end cut will be bigger than a half tile (at about 264mm or so depending on grout thickness and how straight the walls are etc).
Doing it this way means you can use both ends of first the half cut tiles (so you get two rows from a tile if you get my drift), but means the wall will look slightly uneven due to a bigger cut on one end than the other. To look really professional you should split the difference and do a 232mm cut at both ends, but obviously you'll use more tiles (but will have lots of 168mm cuts left if they would be useful elsewhere).
Do the same with the height. ie your wall might look better with a three quarter cut at the bottom and a half cut at the top etc. Also use this theory to work out how to cut around pipes/obstacles - ie it might be better to start with a three quarter tile somewhere if it means only cutting a small notch out of an end to suit a pipe etc.
Hope that makes sense. BTW I'm not a professional tiler so it takes me a while to work out all the above theory, but I always end up with a high quality professional finish.
