- Joined
- 23 Sep 2021
- Messages
- 6
- Reaction score
- 0
- Country
I am just about to replace a downstairs toilet and need a bit of advice. The old toilet is backed onto a vanity cabinet with the waste coming out of the back and into a floor pipe, connected by a flexi pipe. I plan to mount the toilet back against the wall. The centre of the soil pipe is 130mm from the wall, but this will reduce by about 15mm when I put some wood panels up first. The question is am I limited to the type of toilet I buy? As i’ve been told the soil pipe is not a standard distance from the wall. If i do choose a suitable toilet what is the best pan connector to use.. what is the best dimensions to get.
On another note, i've done plumbing on combi-boiler systems with direct mains feed before, but not where I have a tank in the loft and a gas boiler heated hot water cylinder. I want to change the plumbing connections slightly in the bathroom but that means i will need to cut pipework before the Isofix connectors. The valves on the tank in the loft don't close fully so is there an issue/do I need to turn the mains off and draining the tank and cylinder together provided I ensure that the boiler hot water circuit is turned off?
