We've had new windows fitted by a local firm and are generally very happy with the job.
There are just two issues which I'd welcome advice on (they are coming to look but wanting to check I'm not being unreasonable)
One window I've noticed has the external cill much closer to the wall at one end than the other, perhaps 2cm difference, and when I look at the top of the window to the lintel again the window does not run parallel to it. It is as if the window is sitting at a slight angle in the reveal. It looks just slightly off (because it is) - would this be reasonable to want corrected and I guess correcting is not going to be easy?
Second one is more minor - one window the external cill protrudes much less than all the other windows, they protrude by perhaps 3cm but this one by much much less than that. What might cause this, it looks that close to the wall it may not fulfill its function as well.
It's difficult as I don't really know what should be expected so welcome any advice before they come to look.
Thanks in advance.
Thanks in advance.
