Nicotine stains.
13 Jan 2008
Hi all, have a badly stained ceiling with nicotine, what is the best way to prep it and block the stain, thanks for your time!!
As above but then give it a coat of a thinned oil based undercoat before putting finishing coats of emulsion on.
The quickest way is to put a dollup of PVA in the first coat.
Sorry if reply is a bit late but I had similar a few years ago and washed with sugar soap. Was told to use Zinsser B.I.N. I did so and have had no bleed through. Bit pricey but did the job fine. Had already bought some to prime a previously varnished cladded ceiling in porch prior to painting white. Goes off quick and found easier to chuck the roller away than attempt to clean up.
