hey, im new here (hello all !), been lurking for about 3 years and finally joined today.
I have a problem with a combi boiler, it is a Halstead Ace High, about 7 years old
CH - when the heating is on, the boiler fires up fine, gets warm fine, but after about 5 minutes of being on it switches off, leaving radiators lukewarm, it then sits for about 10 minutes and repeats the process (it has an internal mechanical clock fitted)
DHW - largely the same problem, if the heating has been on then the first leg of water is red hot (which i understand), but then after that it fluctuates in temperature, however if the tap is opened half way then sufficiant hot water comes through
initially i thought perhaps the small thermisto's may have gone, apparently the hot water has always been like this, but the CH has only recently started doing it, i was considering changing both of them on the grounds that the DHW went ages ago, and only recently the CH one has gone, but im wondering if it could be anything else. does anyone have any suggestions or remedies for me, thank you in advance
