Where do i start?
The Boiler is a halstead ace 82, i posted a few months back as to what the problem was on here and i'll go thought it again.
First symptoms was when the hot water wouldn't get hot and heating wouldn't fire up, gradually it would only for it to fire for a few seconds then cut out (as if it's trying but not making it) last week it wouldn't fire up at all so i phoned this corgi guy to come and see it.
Right on arrival he said it was the thermistors replaced two and said they needed replacing and that was the problem charging £115 quid.
Half an hour after he left the same problem again (boiler trying to kick up for a few secs) called him up, he came back out and basically said that i needed a new pump did something to the boiler to get it going again but after he left it started to leak water from the pump well the bottom nut (don't think he tightened it properly so called him up again and questioned how he could charge me £115 and the boiler STILL not working if not worse! Yesterday he came out and changed the pump head with one he had (he had to make adjustments to the head too!) but this morning we have a leak AGAIN and its flashing (the green led)
Would appreciate some feedback from you guys on both the corgi guy and the problem.
