Hi Guys,
Here is my problem. I have a Potterton/Baxi combi boiler that has recently given up the ghost. Basically it clicks a lot rather instead of firing up (1 time in 10 it may fire so I am not longer using it). Last week while search high and low for a recommended corgi guy I bumped into a friend who knows a corgi man and had good things to say about him. Great! The guy came out and said all I need is an ignition pcb - about 75-100 quid and he wouldn't charge me silly rates for the labour.
Problem is, he's now got some personal problems and is not in the country for a few weeks. I've had a look at the pcb and basically is looks like there is a dry joint which is arching - I did some research on the net and it seems corgi do not advise soldering pcb's. So here are my questions.
1) Do you need to be corgi registered to soldering joints on a boiler pcb (giving the fact its not going near the gas)
2) I am competent in soldering and electronics but given what I've read about Corgi advising replacing and not soldering pcb's. Do I need to be Corgi registered to replace the ignition pcb? In my opinion this is easier than wiring a standard plug.
3) Should I just leave everything alone and call another Corgi guy which is potentially going to cost me a few hundred quid.
Your thoughts gratefully received
Simon
Simon
