Nissan Micra K12 - steering wheel locked, key not turning
Not unknown unfortunately, but first try squirting some WD40 down the key slot and then trying a spare key, waggling the wheel as usual as you try.
I've fitted new locks to the K11 - that wasn't too bad - but the K12 has little access around the steering column.
John :)
It might have been parked with some load going through the steering column. Try turning the key at the same time as applying a bit of twist to the steering wheel (one way and then the other), to see which way takes the load off the steering lock pin.
