nissan xtrail possible purchace advise
8 Sep 2006
As title realy, Been looking at nissan xtrails as i could do with a more practical car and idealy 4x4 due to work but dont need a big serious offroader so the xtrail fits nicely.
However iv read alot about turbos and intercoolers failing alot, this seems to be more 2003 + when the engine power was upped and became 2.2dci. The ones that i was looking at are the older 2.2Di, can anyone say what thease are like? are the prone to the same faults as the later ones? any advise is welcome, Thanks.
7 Feb 2008
Northumberland
The earlier model doesn't suffer from the same number of turbo failures......that's largely due to lubrication issues and lack of servicing.
It does however have timing chain problems, most of which will be sorted by now.
Intercoolers were bursting due to the inability to withstand boost pressures - again they should be sorted by now.
I hear that it's important for all tyres to be replaced at the same time, with quality, non mixed brands......how vital that is, is anyone's guess.
It's an elderly vehicle now, and only slight warranties will apply - if any.
I guess it's down to low mileage and plenty of care so good luck with the hunt!
I've dealt with a 2.5 petrol X Trail before - no massive faults but poor MPG.
John :)
8 Sep 2006
Most of the cars iv seen for my budget are just over 100,000 miles so was hoping most issues would have all ready been dealt with. I'm not to worried about warranties as iv never bought a car with a big warranty. That's the reason I looked at the 2.2 di, the mpg seems good for the type of car, iv had a diesel befour and liked the lower pull, but currently driving petrol, and it's not to bad and simpler than a diesel but for something like a xtrail or any suv/ 4x4 I think diesel makes more since. What are xtrails like for comfort? Cause I do a drive from Manchester to Carlisle every other month. Thanks.
30 Dec 2008
Cumbria
My wife has a T30 (old shape) X-Trail. It's slightly newer than the ones you're talking about (early 2007 car). We've had it 5 years now and she is very fond of it. Personally, I'm less fond. It's our first Jap car and it as well and truly shattered any illusions I might have had about Japanese build quality! In fact, we've spent more money on it than on her previous TWO cars put together (and they were both Alfas)! Brakes are the main problem. Famous for seizing. relatively easy to work on though, and relatively cheap to source recon. callipers. ALL T30 models have weak intercoolers. The end tanks are crimped on and after a while the crimps let go and they start leaking. Easy to spot when they do, and very easy to change. (Just did ours a few weeks ago, in fact). Early turbos (the sort of age you're taking about) ad weak bearings, but I think most will have been changed by now. I believe there was a recall. Our turbo has been fine. Exhaust gas recirculation valves are known to soot-up, but are relatively easy to access and clean. Some of the suspension bits are a bit fragile -anti-roll bar bushes and drop links in particular. Front wheel bearings also have a poor reputation (although ours is coming up to 90,000 miles and they're fine). Timing chains and exhaust servo vacuum pump chains (yes, it's chain driven!) can be a problem. I think ours might be starting to rattle a bit now.
That's the bad stuff. There is also good stuff. Even in "Aventura" spec, they're a good no-nonsense car. You can get rubber footwell mats and plastic boot liners and they're great for muddy kids. Practical and durable interiors in general, in fact. Best towcar we've ever had (very stable and loads of low-down grunt from the 2.2 diesel). Also superb in snow and ice. Less good on mud and deep ruts (no ground clearance). Basically, don't go thinking it's a Landrover! Up to a point, you can improve offroad performance with a lift kit and more aggressive tyres, but you compromise the on-rod handling somewhat. Remember they have no low-ratio gears and no diff locks. That said, the electronic traction control does a pretty good job. BEWARE, they did make a few 2 wheel drive early models!
For your long motorway runs, they're quite a nice, lazy drive. The suspension is fairly soggy and they're heavy, so they are quite comfy. Get the higher spec cars for nice heated leather seats and cruise control. We get about 32-24 to the gallon on the motorway (depending on how close to the speed limit you care to drive). Much over 80 and you'll be lucky to get much over 30 to the gallon.
Best thing about the X-Trail is the very friendly and informative forum:
http://www.x-trail-uk.co.uk/
If you get one with 17" wheels, the tyre choice will be limited and they can be quite expensive.
