- Joined
- 22 Nov 2003
- Messages
- 2
- Reaction score
- 0
- Country
Miracle of miracles,after borrowing a brand new gas valve,fitting it and attempting to light the pilot with no susses whatsoever, (even after putting some extra heat with a blow torch (very low heat)) I was forced to take it off and refit my old one back, light the pilot ,no problem,turned the thermostat on, and the main gas came on!!!!fantastic!! BUT,I still have no h/w or c/h!....With the diverting valve in mid position and everything turned on , the pump is working but the pipes are not heating up. When the system is electrically off and I move the leaver in the diverting valve,I get the right response,the mechanism inside moves under preasure,but when the system is "on"the leaver is just dangling there and it looks to meas if the stopper inside is over port "A"sutting off the central heating,but this still does not explain why the sytem is not getting hot when in mid position. Could this be a wiring problem? the diverting valve I took off was a "Barlow" the new one is a "Siemens" which looks just like a "Honeywell"
I would be very gratefull for your advise
All the best philipasturias.
