No Central Heating - hot water ok
2 Dec 2018
Hi All
Had the central heating on tonight but no heating, hot water ok. I checked the motorised valves as last time it was one of those that had failed, both seem very slack none is stiff to pull back has another failed ?
Any advice please
If the heating is off and the valve lever is slack, then there’s an issue, however with the heating on, it would be slack, but might not be hitting microswitch. Have you checked your thermostat?
its come on tonight as it should , typical will have to monitor
