No CH/No hot water
27 Oct 2003
Can anyone help?
We moved into our house in July and have not had any problems getting hot water. Recently we've been using the central heating more and more, but this has also been fine.
Suddenly, there is a warning light for low pressure and the boiler wont heat anything.
I thought about bleeding the radiators, but now I doubt if this will help as the problem seems to be with the boiler itself not the radiators.
Any ideas?
Many thanks
Hi Vanessa
It sounds like you have a combination boiler. There will be a feed from the mains to the boiler which you need to open to allow more water in to get the pressure up, then close again.
Boilers vary in how they measure and display the pressure so read the manual or the instructions on the boiler itself so that you know how much water to let in. In my experience with various combis it only take a few seconds to get the pressure up. And you don't want to overdo it.
The mains feed should be obvious with a stock valve on it. Very possibly a red circular 'handle'. But not necessarily!
Good luck
Mary
Before you go increasing the pressure, release all the pressure and check the expansion vessel air pressure. There are plenty of posts on this forum of how to do it. Search for "filling loop" and "expansion vessel". Failure of the expansion vessel can give this symptom.[/b]
