no cold water to wash basin & shower
A
angelf
Called out today customer had no cold water to wash basin & shower. Cold water comes from c/wtank. Used vacs to suck out what I thought may be an airlock then blew no joy. Cant connect the tap (monobloc) to mains to shift problem as the tap is one of those silly linear openings. Can u help
3 Dec 2007
Essex
make a connection on the rising main to the cws and use a hose to blow it through.
A
angelf
cant do that hence the original post....was looking for an ALTERNATIVE method.
3 Dec 2007
Essex
I suspect angelf thinks you are sugesting sticking the mains on the tap end rather than down the cold water storage outlet.
yes or disconnect the tap from the cold supply and blow back to the cws. ;)
