Hi, I have issue with a ferroli 701 optima boiler. The boiler does not fire up when hot water tap switched on.. ie no DHW. However central heating is working fine, and i am able to use hot water when this is running.
I have looked at diagnostic LED'S as stated in manual. I seem to narrowed it down to 3 things
1) faulty Dhw sensor
2) faulty Dhw flowmeter------ or flow switch?
3) Scaled up heat exchanger? ( not from LED's , but off this forum)
not sure where to go next? i am obviously gong to use a Corgi reg professional to do it. I have policy with BG, but they seem hell bent on me buying a new boiler. I admit i am going to have to replace the boiler as aware it is not a great make. However i am having a extension built soon and rather do CH system then. Please could any of professionals out there give me some much appreciated advice. I just don't want to give BG the satisfaction of taking me for a ride. I am going to give my business to good independent plumber.
cheers
sorry forgot to mention that cold water intel valve was leaking, ie staying open, i replaced that as water wa dripping from outlet drain. Could this valve have damaged flow meter?
thanks
cheers
thanks
