Hello All,
Have been in our house now for 2 years and never had our system work properly. The DHW takes at least 8 hours to heat enough water to have a bath and the radiators have never worked. Occasionally one may come on for a few days and then stop working again.
I decided to give it a go with a mains water flush as described on this forum and all was well. Lots of crud etc flushed away. After the system still was the same so probably didn't do a good enough job.
A day later, however, I now have no heating or hot water.
The boiler fires up for about a minute and then goes off. The flow and return pipes from it remain cold. After a while it fires up again and the pipes remain the same.
Have bled the system and there appears to be no air in it.
Is it possible that whatever may have been an original blockage has moved elsewhere and now stops any flow through the boiler (or has knackered the pump)? Have removed the bleed screw of the front of the pump and tried to turn whats underneath but access is very cramped so not sure if I was successful.
Have a spare pump so is it worth swapping it out or is it just likely to break that one as well.
Would really apreciate any advice to help.
Many Thanks
Aggi
Many Thanks
Aggi
