My daughters ch has been lacking output for some time. On first inspection the boiler return was taking along time to warm up. Although the pump was making all the right noises we speculatively changed it. No difference.
So we then flushed the system with mains water. After putting it all back, good temperatures now appear on both sides of the boiler on hw and bypass.
The rads are more of a mystery. When we began to flush them there was no flow until we realised the TRVs were all directional and so changed flow direction. Going round each rad individually, all subsequently gave good flow.
Back in the complete system, with rads only, the return temp still shows no flow. From the flush and from what little heat gets through we know that system flow is the correct direction.
The 3 port valve appears not stuck because the hw side correctly goes cold when demand changes.
Do directional TRVs need a minimum pressure? Can a 3pv fail in such a way that the rad side can be permanently shut even though hw side switches properly? (The 3pv was taken off to flush but while off we didn't make the system live to eyeball the innards.) Any other possibilities to consider?
