I have an Ideal-Standard Concord W RS/CF. Both hot water and central heating working fine last night. This morning no hot water but central heating OK. Hot water light on unit not lit but heating light is lit. Any ideas?
S plan has two motorised valves a Y plan has one. A synchron motor will set you back ten quid plumber to fit one if it is the problem obviously, around 40 pounds.
