No hot waer
26 Oct 2006
Berkshire
I have an Ideal-Standard Concord W RS/CF. Both hot water and central heating working fine last night. This morning no hot water but central heating OK. Hot water light on unit not lit but heating light is lit. Any ideas?
If the system is a s - plan design then you will find that the synchronic motor has probably packed up on the hot water motorised valve.
S plan has two motorised valves a Y plan has one. A synchron motor will set you back ten quid plumber to fit one if it is the problem obviously, around 40 pounds.
