Hi
I noticed today that we have no hot water and having investigated further I have established the following:
- believe the boiler is OK as when I turn the heating on the boiler fires up
- otherwise the hot water timer is on and "calling for heat" but the boiler doesnt fire - otherwise everything seems dead
So I assume this is a valve or pump issue ?
I can see a valve near the hot tank and I have pump/valves upstairs in a cupboard but I havent yet worked out what is what.
What is advice on how to track down the problem? And is my assumption of a faulty valve or pump the likely cause ?
Any tips/advice on this would be much appreciated
Cheers, David
Cheers, David
