no hot water c/h ok vokera maxin 24e
15 Jan 2004
hi guys
getting hot water from taps when c/h on only?
checked changed diagthram, checked diverter pin on microswitch all ok?
both pins operating correctly could it be faulty microswitch?
any thoughts appreciated ,
You cannot do much checking in a boiler without a multimeter!
Resistance of sensors?
"ON" resistance of microswitches?
ok found it m8 pcb board gone totally burnt out at plug to microswitch only??
must been a short somewhere , will try to source a new board , how much would this cost ?
About £100-£150 ?
Could you have shorted a microswitch connector to chassis?
OP There is 240 volts on the wire. Do NOT attempt to short cicruit or touch the wires on the microswitch. 240 volts live supply caution to be observed here.
If the pump not running, then follow the manual flow diagram if REALLY must go there
thanks guys ,ordered a new board got 1 cheap on ebay 35 £,, there was a slight leak which i have now fixed that seemed to be dripping on to said microswitch, swapped switches for heating side to check if ok ,it is so just board at fault still have hot water when heating is switched on so will be ok until new board arrives noticed the 240 v on microswitch thanks isolated before checking board etc
