I'm having a bit of a problem with our Vokera Maxin 24e combi boiler. When the hot water is run, it begins hot, and then goes cold, then goes hot again, etc. The boiler runs for about 30s on and off and straight back on
Its been cleaned, including the fan and venturi, and the thermistor has also been replaced.cleaned the cold water feed filter out plenty of flow to tap.
This has not fixed the problem.
Works fine if the heating is calling.
Any ideas?
Read more: //www.diynot.com/forums/plumbi...roblem-hot-cold.327959/#2785522#ixzz2VAEysvDV
Any ideas?
