no hot water onmaxin 24e
28 Jan 2008
Tyne and Wear
my maxin 24e combi boiler has lost the ability to produce any hot water. this fault started intermitantly but now is permanant. it will not produce hotwater under any setting of dials. another fault which i do not believe is a factor is that the temperature part of the dual dial has dropped tothe position 8 on a 12hour dia.any help with this problem would be appreciated.could it be it just needs aservice?l
if heating ok i would suspect the flow switch/diaphragm, if no heating then lack of water seems likely
thanks mick microswitch is ok .heating works so diaphram is the most likly cause. thanks again
