I have no hot water at the moment in a house which I have just bought. It should be heated by the hot water cylinder shown in the picture below
Other than having no hot water, I cannot actually tell whether the cylinder is working. Only previously had central heating with combi boiler so not come across a cylinder before . The electric fused switch is set to on BTW. Does the cylinder make a noise as it is heating the water because at the moment it's silent?
I am going to check/swap the fuse in the spur unit which the cable comes out of and I having removed the cover on the Imersion heater 'element', I will check that there is power getting to the electrical connections but are there any other simple checks which I can do before I think about replacing the Immersion heater element?
Also, when I removed the cover (which says Newlec Type NL27PT 3.0kW 240V, 2.76kW 230V on it) next to where the Incoming wires come, there is a small dial with temperature settings on it from 50 degrees to 80 degrees. It was set to 70 degrees and I have turned it upto 80 degrees but still no hot water and no sound of it heating.
If I do need a replacement for the Newlec Type NL27PT Immersion heater, what are any equivalents. I have had a look on Screwfix and there are 11" and 27". Does it matter which size is fitted?
Any advice would be very much appreciated.
