No hot water from shower after the morning unless hot tap on
27 Sep 2010
Here's my scenario, hope someone can help us with an action plan!
I have a Mixer Shower (Triton dual control), Combi Boiler (Worcester 24CDI) and live in a very hard water area (West Reading).
After about 7:30AM, if I take a shower the boiler will not kick in and provide hot water unless the hot tap in the sink is slightly on. If I have a shower very early in the morning this is rarely a problem. Later in the day I am often unable to have a hot shower unless the hot tap is on nearly full - the result of which is a trickle from the shower and a frustrated me!
It seems like it needs the additional flow coming out from the hot tap before the boiler will 'notice' that it needs to start heating the water.
I'm assuming that there is a loss in mains pressure due to everyone in the street having a shower which is built up overnight? However, pressure from the shower still feels reasonable so I guess this isn't the main issue, just something that contributes to it?
From looking around the net and forums the issue maybe one of the following:
  • The Flow Regulator in the boiler
    The Mixer Valve in the shower
    The Thermostatic Cartridge in the shower
    Some sort of blockage
    Some sort adjustment required with the shower
If it is relevant - The shower was fitted probably 4 years ago (guess) and the boiler is serviced/repaired due to issues caused by the hard water around once every 18 months. I have descaled the shower head which hasn't improved the situation.
I'm not a plumber but a competent DIYer. Any advice would be appreciated so I would know whether to tackle it myself, call my Boiler Engineer or get the Plumber in.
Many thanks in advance. :P
metalfury
It sounds as if the diverter valve is failing.
Its a pig of a job on your model and took my trainee about 2.3 hours with good access.
I usually suggest calling Worcester on a fixed price repair basis.
But if you call Mike Bryant and he likes to work on them then he will probably be able to do it for you.
Tony
Thanks Agile :D your reply is appreciated.
Do you mind me asking how you determine it is the boiler DV rather than the shower not demmanding enough water?
I know Mike, so will give him a call and see if he is interested in the work.
Cheers again
metalfury
