No hot water only luke warm
14 Nov 2007
London
When i turn the central heating or hot water on it only gets luke warm, the boiler is deinately firing but not on it's full capacity as i know it (seemed louder before).
I inherited an Ariston boiler, not sure of the model
can anyone help a newbie out and tell me what to look for, or what it may be?
Is it a combi? Model?
Are you expecting too much - does the water get hot if you turn the tap down, to about 8 litres/minute?
It ie a euro combi a23
I have had it just trickling out and it is only slightly warmed, and it only happens sometimes, other times it's very hot
The radiator in central heating mode don't get at all hot either and other times they do.
it seems very random
It's as if the boiler is on but not heating anything up very hot when this happens.
It also does not shut off sometimes so i have to manually turn it off, not sure if this helps?
If its an intermittent fault then it needs tests carried out while its in the fault mode.
Anything else would just be guessing!
Tony
this sounds similar to my issues, im also a Eurocombi owner unfortunatley, although before this mine had worked fine
It could be a combination of the heating sensor and main flow switch malfunctioning maybe.
I can think of several faults those have which lead to similar problems. It's bit like saying a car is mucking about/underpowered. Needs a visit.
ok then looks like i'l have to get someone in then, are there any tests I can do to help or elimate certain problems?
Your help is appreciated
any test I can do to help solve what it could be,
any examples of what could be wrong at all?
over the phone my man said it sounds like it could be the thermostat
does this sound right to anyone in the know as his asked me if i want him to get one?
is his normal practice
