No hot water - radiators working.
17 Aug 2011
Birmingham
I have a Baxi Duo-Tec Combi 40 HE A.
The heating aspect of the boiler is running just fine, (its hot and sunny, I don't need it but it's running fine). The hot water is not.
When I turn the hot tap on I get cold water. The boiler hot water light comes on, and then the temperature display rises rapidly. It gets up to 98/99 degrees and the boiler starts to thump and fart.
On advice from here I fitted a new diverter repair kit, and a new motor to successfully fix a different problem back in February (https://www.diynot.com/diy/threads/radiators-not-heating-up.476607/)
The system has been power flushed and a magnetic filter fitted.
Any advice as to what this might be the problem / fix.
Thanks guys.
Oh and it seems there is a fair old amout of water from the black rubber hose at the back of the boiler that comes down from the upper chamber. Opening up that chamber, there doesn't seem to be any clear source of the leak. The water coming out is yellowish (like radiator/inhibitor mix).
