no hot water
21 May 2008
Liverpool
hi , no water comining out of the hot water pipes but is runing up till it gets to boiler centrel heating working ok, thx you
have you got a hot water cylinder and a cold tank in the loft?
is the boiler pressurised (will have a pressure guage on it) or is it fed from a small tank in the loft?
have both these tanks got water in them, and is it up to the usual level (there will be a tide-mark)?
It may help if you say what model of boiler you have
hi it is a britony conbi se 80 boiler we empteyed hot water out to do job now we have put water back on hot water does not flow but centrel heating is ok
One assumes that if the work was on DHW pipework after the boiler then you turned off the water inlet to the boiler.
The immediate assumption is that the valve has not been turned back on?
Tony
