HI Chaps,
I recently changed a radiatior refilled the cylinder etc fired up the boiler and the rads are all working fine but I have no hot water, the cistern filled OK this is an old system and it has two two way diverter valves. When I switch the time clock to hot water only the first diverter valve operates ok but the second does nothing, hot water is getting past the first diverter up to the second but not past it, everything was fine before I changed the radiator, the manual lever on the second diverter is doing nothing if I move it back and forth any ideas
