Hey all.advice needed please.apologies in advance as i know nothing about central heating systems but i will try and give as much info as i can.
i have no hot water at all. i have a hw cylinder type system with a baxi boiler.
when i switch on the water with the central heating switched off, the boiler fires up but it heats up all the radiators in the house but not the water???
of the two pipes coming from the cylinder the lower pipe is very hot and the pipe slightly further up is much much cooler.
probably worth mentioning i had to change a tap washer so had to drain the hot and cold water. i did this by turning off the main stop cock and opening up all the taps.although i cant say whether the hot water worked before this as we haven't used it for ages as we always have a shower.
any help greatly appreciated.
