I live in Gloucester and used the time we spent without water (after the flood?) to replace a stuck stop tap and some shoddy pipework nearby as the stop tap chamber in the road was blocked and it seemed like a good opportunity. Must admit I was a bit nervous I would return from work and find the house flooded if I'd done anything wrong as we weren't told when it would return.
Anyway I have recently realised that I forgot to put an insert in the 25mm MDPE pipe, should I get the waterboard to clean the chamber out so I can turn the water off and put an insert in or should I assume that as it doesn't leak now it never should?
Many thanks
Many thanks
