I am replacing my old external water mains pipe with 25mm mdpe and was just after a bit of advice on fitting a new stop tap. I have 15mm speedfit pipe (white) internally and wondered what stop tap you recommend to fit between the two. I guess i will need to put inserts into both pipes that are connected to the stop tap.
any advice will be gratefully received.
