No More Nails for sliding wardrobe track
5 Oct 2004
Essex
I need to put a top track on a 3 metre wide sliding wardrobe. Unfortunately just found that there are no crossing joists for the top track screws (they are running parallel and the track is in the middle making them useless for this purpose).
I was wondering if I could use no more nails. Could anyone please advise if they are good at bonding metal with plaster? I would also use plasterboard screws on top of no more nails but doubt if screws would add a lot of strength without no more nails.
Thanks..
You are proposing to hang the doors from a piece of plasterboard, using mainly glue and screws into plaster.
Fit some cross noggins between the existing joists and then screw securely through the ceiling board into them.
Tony,
I am not proposing to hang the doors to piece of plasterboard..
the doors run on bottom tracks, they are only held into vertical position by top track, there is no weight on top tracks.
Would the top track not be secure with a good bond along the entire length of plaster board?
For a while maybe, usually not that hard adding a few noggins between the joists in the floor void above. What's the floor finish above the ceiling? Floor boards or chipbboard or what? Please don't say its a loft with no boards.
Hi Freddy
It is what you don't want to hear, i.e. loft with no boards (mainly)..
But should that not make nogging easier, as I can clearly see the joists, stand on them and apply the blocks where screws are coming out from the top track?
Ahh, thought you meant top hung, but still fix the noggins and have done with it.
You will have it all done and secure before you can get round to buying no more nails. You have the easiest ceiling possible to access.
