No pilot ignition on netaheat
11 Aug 2007
London
demand > fan runs> pressure ok and gas valve opens with soft clunk> clicky clicky goes spark generator> pilot lights > main gas burners ignite
Except the spark generator is not going 'clicky clicky' and so sequence holds at that point
PCB or the generator at fault? Relay all fine and is under 9 months old
BTW I am aware that Netaheats have killed more people than fred west etc etc although I have to yet to hear of one confirmed case!
I am not taking the case off merely hoping to replace a failed item.
S
CLicky box has only three terminals, so if it has mains up two of them and no sparky sparky from the other one, clicky's buggadup. Check between earth and the terminal in case it's just the ht lead.
If no 'clicky clicky' I would check the aps under the boiler, or the tubes to it.
Wouldn't have thought 'soft clunk' would be heard until 'clicky clicky' had started and pilot light proved 'burny burny' :wink:
thanks, Im away from home now but when I get back on wednesday Ill check further, hope no cold spells till then or wife and kids will not be pleased
im ok, im in a hotel!
S
if under 9 months old, get potterton to repair under waranty would be my reaction
Why should Potterton repair a 20 y.o. boiler just because the relay was changed none months ago?
In their various models they were sold over many years.
The later ones had a proper PCB but the early ones mostly hard wired round an octal or 11 pin relay.
