no pilot light
26 Apr 2007
Cheshire
I have an Ideal C80FF boiler which just went off last week.It doesn't have a thermo coupler. Any ideas?
About the only thing you can do is check the system pressure and the overheat stat.
Tony
pcb's are very common on these to go wrong. Do you mean its completely dead? check fuse at switched fuse? or is there red lockout light on
Red lock out light indicates ignition problem. either pcb or reset button switch.
