intermittent hot water Ideal Boiler C80FF
16 Apr 2005
"Ideal Boiler C80FF"
We have intermittent hot water. It runs hot for a few minutes, then the boiler clicks off. Then after 5 minutes of running cold the boiler kicks in and it runs hot again. Then it clicks off after another 2 mins. And so on. Very annoying when running a bath or the shower.
Any ideas?
Sludge in secondaryheat exchanger. Very common topic!
Right, looking at the manual that does look DIYable- few screws to remove and replace it- no need to touch gas. Is this correct? If so I'll give it a go.
Or is it cleanable? If so do I just flush it through with water?
try to clean with water first. if it requires something more aggressive see your local plumbers merchant to what they have got available.
Well, all done. Took less than an hour top get the exchanger out, easy to do.
I ran some fernox sludge removing stuff through it but I think it is still sludged up in there. Certainly you can here it swishing about in there when you shake it still.
Replaced it and it is better- longer intervals between it switching off. But I suppose a new one is the only real solution.
Best price online is around £90- is this about right for one?
Thanks for all the help so far.
