About 2 months ago we had a service from British Gas on our Vokera Linea 28.
We've had the boiler about 7-8 years.
As part of the this service they replaced the flow and non-return valves, as the filling loop was blocked and wasn't filling the system properly.
Anyway, after this all seemed to work fine, until about 2 days later the power to the boiler cut-out.
We called BG out again and the guy just replaced the 3amp fuse in the fused spur and all seemed to work fine.
The problem is that in the last 2 weeks the power has been cutting on and off and we've gone through numerous fuses......
We've had an electrician look at the wiring and all seems to be okay, infact he changed the fuses just yesterday morning and everything was working.... for about 3-5 hours then it went off again and changing the fuses doesn't seem to work.
We have BG coming out again but wondered if anyone could offer any advice?
Could it be the part the BG engineer fitted during the service causing the problem as we've never had this issue in the last 7-8 years of having the boiler?
