Noise from first floor on Ground Floor
22 Aug 2013
London
Hi All,
I recently moved to a semi detached house. I can hear noise of walking on first Floor from ground floor.
can anyone please suggest me , how can i resolve this please ?
Many thanks
Regards
yash
Then do as the man suggested and put thick carpet and underlay down.
cut the legs off the upstairs ocupants
Install this?
houses converted to flats years back had no sound proofing.
I did the below.
Seal all gaps in floorboards and under skirtings with acoustic sealant continuous bead.
fit 6mm plywood,well secured.seal as above again (continuous bead).
2 layers of sound proofing mat.
acoustic carpet underlay (best you can afford)
Decent carpet.
Not cheap to do but the cheapest option and it worked.
