Noisy Actuator which will not switch off
28 Jun 2006
Dorset
Noisy Actuator - we have a Drystone ZA5 (Invensys?) that will not turn off even when all central haeting controls are off?
Is this faulty? - should it run all the time?
With being in the airing cupboard the noise goes on all through the night.
Any hep apprcaited.
Steve
I think that you mean "Drayton"!
I would suggest that it probably is mechanically faulty as most designs stall the motor at the end of the travel.
Sounds as if its lost a cog on the quarter cam.
Thanks Tony, so I guess I need prof help to replace the thing!
As an amateur is there any simple actions I can take?
I know the cost of the item is not too much £30-40 - what should it take to replace it in time?
Thanks again
Steve
Newer design has easily removable head unit (no tools req'd). If so you can manipulate the valve shaft with a small spanner, and determine whether the fault is in the valve or head.
