Ok whilst im on here i might as well sort all my diy problems.
I changed our cold water tank last summer. It was an old metal one that had completly rusted out. All when to plan no problems. Great, well until we started using the hot water. The hot water is on its own electric pump as there is no pressure in my flat. Basically the pump sounds like it has air in it. It works but will then start screaming as if there is air in it and the water pressure goes down. Then if you turn the tap off and put it back on its ok for a bit.
Its been doing this for months. I have tried cleaning the filters in it but can't find anything in them. Is it basically for the bin or can it be fixed ?
Thanks Chad
Thanks Chad
